12 V
Obserwujący (4)
- tim morlandSilver
- Newby7Bronze
12 V
I have had a look at that article but unable to gain much information as it says 'club members only.
May i suggest that you try and contact Mancave to see if he could help.
12 V
I liked the concept and ordered the parts need.I have started to build the unit and wanted to figure out plus and minus of the fan and mister before hand for the wiring to power.The ultrasonic mister has arrived but there is no indication of plus or minus on the unit to help me with wiring it up.
Hope this helps a bit Martin.
Rick
12 V
Do you have any more information and some photos ?
12 V
Any help please.
Rick
12 V
Rowen
12 V
The application will be to power a 12v. 25mm fan and a 24v ultrasonic mist generator (threw a 12v to 24v converter).
The battery needs to be powerful yet small enough to fit into the space (2"Wx4"L) needed but I don't want to put out big bucks on the battery.
Any help appreciated.
Rick
12 V
You could also use a step up transformer/voltage converter/step up converter (various names). These are the devices that convert 6v to 24 volts so that you can use those misting machines as smoke generators. They only cost a few pounds/dollars. Some of them have built in volt meters others you need a voltmeter. They are adjusted by a small potentiometer that you turn with a screwdriver. If you use one, just make sure that you buy one that will give enough current to match the fan. Have a look at this website to give you some idea of what I'm talking about.
https://www.componentshop.co.uk/voltage-booster.html
I use power boosters and reducers all the time to generate different voltages from one battery. Saves having lots of batteries of different voltages.
Good luck Tim
12 V
2 6 volt SLA batteries connected in series should give you no problems. Just remember to charge them individually.
I have the same set up on my Tarpon
12 V
Alternatively yes, the 11.1v battery will also work. I’d think a 12v fan would likely work down to around 8v.
Stephen
12 V
Can I use 2 6v batteries and y connect together will that give 12 v.
Will a 11.1 v battery be able to power the fan.
Any help please.
Rick
Polubione przez
Ładowanie…
