Switch
Rozpoczęte przez Newby7
5 odpowies 10 lubis Ostatnia aktywność: 6 lat temu
Switch
Hi Martin,
Dead on DPST is correct👍👍
Polubione przez Martin555
Switch
Hi Rick,
To switch both wires i think the switch is called a DPST (double pole single throw)
There are all sorts of switches that will do different jobs.
Polubione przez RNinMunich and Peejay and
Switch
Hi Rick,
Normally it is the red wire.
It also depends on what type of switches you use as you can switch both wires at the same time.
Polubione przez Peejay
Switch
To set up a switch for the battery which side red or black is better or is ether side OK.
Rick
Polubione przez Ianh and Martin555
