Thanks Roy for the advice going to try get a sheet of thin metal I’ve seen in B+Q it’s pretty thin so going to cut template if screen out and make the window frame on both sides of the screen then hopefully bend them both to match the back and front of the screen then stick to top of hull long way off that yet lol white metal fittings kit next
Decal on cabin was already on I e found them on the Hobbies site in a pack I think will see if I can find and send through just found them if you mean these Ron just type in fairey huntsman stickers https://www.modelrealm.co.uk/shop/search.html
[{"id":"169539755481","name":"169539755481.png","caption":"","url":"https:\/\/pl.model-boats.com\/media\/169539755481\/l","thumbUrl":"https:\/\/pl.model-boats.com\/media\/169539755481\/s","isImage":true,"ext":"png"}]
Excellent work! Very sharp!
[{"id":"169539335390","name":"169539335390.jpeg","caption":"","url":"https:\/\/pl.model-boats.com\/media\/169539335390\/l","thumbUrl":"https:\/\/pl.model-boats.com\/media\/169539335390\/s","isImage":true,"ext":"jpeg"}]
If / When you do the fitted round screen I have done a couple of these now. I have taped off the outline of the supports and used 2 coats of paint to represent the frames seems to work OK.
See My Harbour Huntress.
Well I think for a first time restoration with a huntsman with a bit of guidance I don’t think I’ve done too bad couple of days sanding and primer and a bit more filler and a sand and another couple of coats of primer should do
[{"id":"169538048131","name":"169538048131.jpeg","caption":"","url":"https:\/\/pl.model-boats.com\/media\/169538048131\/l","thumbUrl":"https:\/\/pl.model-boats.com\/media\/169538048131\/s","isImage":true,"ext":"jpeg"},{"id":"169538048147","name":"169538048147.jpeg","caption":"","url":"https:\/\/pl.model-boats.com\/media\/169538048147\/l","thumbUrl":"https:\/\/pl.model-boats.com\/media\/169538048147\/s","isImage":true,"ext":"jpeg"},{"id":"169538048419","name":"169538048419.jpeg","caption":"","url":"https:\/\/pl.model-boats.com\/media\/169538048419\/l","thumbUrl":"https:\/\/pl.model-boats.com\/media\/169538048419\/s","isImage":true,"ext":"jpeg"},{"id":"169538048433","name":"169538048433.jpeg","caption":"","url":"https:\/\/pl.model-boats.com\/media\/169538048433\/l","thumbUrl":"https:\/\/pl.model-boats.com\/media\/169538048433\/s","isImage":true,"ext":"jpeg"}]
